Efficiency and Resonance
There is a question in my mind that I can't find a good answer for it. I hope you can help me. Is there any relationship between the resonance frequency of an antenna and its radiation efficiency? I mean for example if we have a microstrip antenna not working at its resonance frequency, can we concluded that its efficiency will be low?
Thanks for your possible help
RE: Efficiency and Resonance
Adjust the antenna for operation at resonance then adjust the matching for a good match for best efficiency.
this is a good question. The radiation efficiency has nothing whatsoever to do with resonance as such. The radiation efficiency is the ratio of power radiated to power accepted by the antenna. It is given in antenna text books by the ratio of the radiation resistance to the total resistance. The total resistance is the radiation resistance plus the loss resistance.
So, it should be clear that to get the best (theoretical) efficiency you simply need to maximise this ratio of resistances. Now in practice if the reactive part of the antenna’s impedance gets very high the theoretical "lossless matching network" used to match the antenna to the feedline and amplifier will give losses that need to be considered when calculating the overall system efficiency. Thus it is highly desirable to have the antenna as close to the characteristic impedance of the system as possible, minimising the amount of matching needed.
In practice the reactance of an antenna can increase so rapidly away from resonance that the overall system efficiency will be low if the antenna is run off resonance.
Playing with the feed point can give a match closer to Zo but as you suggested it is generally highly reactive and will have a narrow bandwidth.
In the case mentioned above, off resonance might make it difficult to feed the antenna, but reflected power isn't quite the same problem as (the proper meaning of) low efficiency (except that the matching network will cause additional loss).
