slddrw inserted into wordXP does not take the BOM with it
Gidday
I have been trying to insert solidwork drawings into a word document for a manual. I have been inserting as a linked object, but the BOM is not inserted with the drawing. The rest of the drawing is fine. I have tried several other drawings with the same outcome. I have also tried with other word docs.
I am operating XP, word XP, sw04 sp4.
I have also tried to insert a pdf of the drawing instead, but the object only appears as an icon!!!
Thanks in advance.
Ryan
Thanks in advance.
Ryan
RE: slddrw inserted into wordXP does not take the BOM with it
1) Print screen (Keyboard)
2) Edit paste in Word.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
I want to have a slddrw linked object, because the manual will be evolving, and i would like it to update automatically when the sw drawing is updated. So linking a dxf would not be ideal because the person that updates the slddrw would have to also update the dxf.... We have been trying to have only one type of drawing, so would like to keep away from dwg/dxf/pdf etc. Also a screen grab or dwg,jpg etc would not be ideal. But i maybe have to do either if there is no solution.
Have you guys tried to insert a slddrw into word? Does it take the BOM with it? Or is it just my setup?
Does anyone know if sw05 has better integration? We are upgrading shortly...
Ryan
