AHU'S COIL PRESSURE DROP
hi every body,
ahu with the following previous data at 46 c outdoor:
chilled water in : 7.0 c
out: 12.0 c
pressure drop : 7 psi
booster pump
indoor 22-23 c
NOW after adding :
1 3-way globevalve
1 balancing valve
stop booster pump
increasing the water flow rate (may be 1.5)
we have :
out: 9.5 c
pressure drop : 15 psi
but!!!!! indoor 25-26 c (at the same load)
why?
is it true :
1. increasing flow however will reduce supply air temp.
2. lower in-out means lower air temp.
out: 12.0 c
booster pump
indoor 22-23 c
NOW after adding :
1 3-way globevalve
1 balancing valve
stop booster pump
we have :
out: 9.5 c
why?
is it true :
RE: AHU'S COIL PRESSURE DROP
BTUH = GPM x (Tin-Tout)x 500 you can see if you increase the gpm the btuh will increase...BUT that assumes that delta "T" remains constant; in your case it goes down like said because of the reason above.
really,it is not clear to me that increasing flow will increase air temp!
Actually increased flow increases turbulence and so overall heat transfer coefficient.
In my opinion your flow rates might have reduced.
note: we have 12-15 psi water pressure drop, is it normal?
sorry bout that!
