Welding Nitronic 60 to 316L Stainless Steel
What would be the preferred filler metal for welding Nitronic 60 to 316L stainless Steel using the GTAW process?
RPB123
RPB123
RE: Welding Nitronic 60 to 316L Stainless Steel
I have come across this situation where we had to deposit Nitronic 60 weld metal over a 304L substrate for increased galling resistance. For your case, if you are joining Nitronic 60 to 316L stainless, I would use a Nitronic 60 bare wire (AWS 5.9 ER218) with the GTAW process.
I attached a spec sheet for your review;
www.australwright.com.au/DataSheets/Alloys/Special%20Products/Nitronic%2060%20S21800.pdf
Also, keep the interpass temperature below 350 deg F during welding. I would perform a liquid penetrant test of the weld just to make sure you have no problems.
RPB123
