URGENT - SOME FATIGUE CYCLING TERMS
Can anyone give any info/definitions of the following?
-coffin-manson fatigue coefficient
-hardening exponent
-coefficient of plastic resistance
RE: URGENT - SOME FATIGUE CYCLING TERMS
Look at the first coupld of chapters of this book
Fundamentals of Metal Fatigue Analysis
---bannantine
Thanks.
Those parameters are mainly related to local approach in Fatigue engineering.
Coffin manson characterizes the plastic area (equivalent of low cycle fatigue)
Other parameters are related to Ramberg-Osgood cycle hardening/softening material curve
PhV
As I found Bannantine quite hard to get hold of, here's my take on these parameters:
A strain-life curve is basically made up of two log-log straight curves for the elastic and plastic strains;
elastic coefficient = fatigue strength coefficient
elastic exponent    = "       " (Basquin) exponent
plastic coefficient = "       ductility coefficient
plastic exponent    = "       " (Coffin-Manson) exponent
Basquin between -0.05 and -0.12 for some typical steels, Coffin-Manson from -0.5 to -0.7?
Safe Technology of Sheffield, UK have provided some good advice, courses etc in the past...
Good luck!
Try looking for Bannanntine at www.bookfinder.com a website that checks hundreds of new and used bookstores. You can find just about any book you want and can compare prices from many places.
Doug
Doug
