Undersize 316 Shaft Repair
I have a shaft made from cast 316 SS which has been machined undersize approximately .035 inch. The undersize surface is used to support a roller bearing. It has been recommended to buildup this surface by "spray welding" and then re-machine to the correct diameter.
Is spray welding the preferred method of repair in this case? Would chrome or nickel plate be better? Comments?
Thank you for the help.
Fracball
Fracball
RE: Undersize 316 Shaft Repair
We repaired SS shafts, all were wrought material, by welding or installing a shrink fit sleeve.
To weld this I would undercut the shaft in the undersized area to give at least an 1/8" diametrical undersize. Slightly taper the ends of the under cut. You might want to weld with longitudinal stringers rotating 180° on each pass depending on the diameter. Once you start, keep welding.
Being cast SS it is extremely hard to predict which direction it will go.
Come back with the Dia.
Plating the shaft up to 0.035" is kind of thick for this application, typically you only want one thousand of an inch or so for coat thickness. Anything more and flaking, peeling, cracking become a problem. Adhesion works best with thin coating followed by baking, like in the electroless nickel application.
Weld repair is indeed the industry standard for repairs of this nature. I like the longitudinal stringer idea, diametrically opposed would provide surface strata strength. Note also since you are to machine back the shaft to the correct diameter, any warpage due to thermal stresses would be corrected.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
unclesyd: I am referring to a thermal spray/metallizing process. I do not know any more details about the process - yet. The diameter is approximately 3 inches.
Thanks again.
The problem with these types of coatings as with the "metal spray" type repair is low bond strength. Typically HVOF coatings have about a 10,000 psi bond strength.
Machining a press fit or shrink fit sleeve is what we do, it's faster and holds concentricity without damaging the shaft.
Shrink fit sleeve is also a good option.
Welding a cast SS shaft may create some problems (as the temperature will be above recrystallization temperature and subsequent problems with carbide precipitation). But Unclesyd has profound knowledge in these matters and I think he will clarify my doubt.
work-hardening might be an additional benefit?
What type of tolerances end to end and surface do you have. Also, weld will not clean up worth a damn so your surface finsih will be spotty in areas.
The shrink fit has the most promise. However, for a 316 shaft at 3" dia., at what point do you punt and make new. IT doens't sound like an expensive part relatve to the work your about to put in it.
We had no problems with welding SS shafts and were able to achieve most any finish required. We never had problems with bearing areas. We found it expedient to finish in the weld metal not in an weld interface, that is the reason for the slight under cut suggested. The slight taper keeps a demarcation line from being a problem.
