SILICON CARBIDE NITRIDE
I need to determine acceptable torque limits for the silicon carbide nozzles that we produce. They range in size from 4" up to a 16" nozzle(300lbs). The flanges have the same number of holes and the same bolt holes as Class 150 flanges. Bob
RE: SILICON CARBIDE NITRIDE
What sort of stresses are involved on the whole assembly--fluctuating or static?
Can you perform a trial and error test, or are you writing a spec?
