Measure Heat Generated?
I just wanted to double check this formula with you guys..
I have 108 Fluorescent Lights that run at 18 Watts...
I want to figure out BTUh. So the formula would look something like..
18/110 = 0.16 amp draw of each light
18/.2930711 = 61.42 BTUh for each light
Is that correct.. because that just seams REALLY high to me for some reason.
RE: Measure Heat Generated?
x3.412
Friar Tuck of Sherwood
1 watt = 3.412 btu
There was no need to calculate the current to find the BTU/hr
TTFN
