Effect of storm duration on Peak Flows
Hi there!
I wanted to know the difference in the effect of storm duration on the Peak flows. I am reading a report that has used 12 hour storm duration to do the culvert design. Catchment areas vary from less than one hectare to more than 1000 hectares. I think 12 hour storm would result in lower peak flows values than those resulting from 3 hour or 6 hour storms, and hence 12 hour storm does not represent the worst case scenario?
Thanks!
KH
Thanks!
KH
RE: Effect of storm duration on Peak Flows
Good luck
