Inflection point from curve analysis?
Is is possible in V5 to get the exact inflection point(s) when analyzing a curve?
We can see the inflections in the graph.
RE: Inflection point from curve analysis?
Have you tried point extrema?  I think this requires a gsd2 liscence.  This tool lets you put points on curves and surfaces? with regard to other elements ie max/min distance from..
Apply curvature analysis, then switch on particular and then RMB on spikes;it will give you the option to keep one or all inflection points, max/min etc..
Hope this helps.
D
thanks Jeff and D...
I printed out your suggestions and have only had a brief chance to try them out. R-clicking the spikes seems to provide more data.
I'll let you know,   ...Jack
