hds-5 entrance losses
Does anyone know how the coefficients in Table 12 of HDS-5 were developed?  I've never seen any of the background info, assumptions, or tests that were used, so although I use them, I've never completely understood them.
For example, is the grooved end of a projecting concrete pipe (which I assume is the "bell" end) really more efficient than an end section?  And if the pipe is mitered to match the fill slope, wouldn't a lower coefficient make sense because the opening area is larger?
In the footnote, what do they mean by an end section with a "closed" taper design?
Thanks for your help!
RE: hds-5 entrance losses
mitered openings cause a loss of energy in the flow due to the change in momentum.  Typically, the water must change direction and the jet must contract to enter the pipe resulting in a momentum and contraction energy loss.
