AutoCAD failed to install
I have tried to install AutoCAD Map5.  It hung up at the end and froze my PC.  After I forced it to shut down add/remove in my controll panel did not show an Autocad entry.  The folders were on the hard drive like it had been installed, even a short cut on my desktop.  When trying to open it gives me a fatel error.  So I try to reinstall it and it doesn't do anything.  You double click the exe and nothing.  I need autocad installed on my PC for work purposes soon.
Any help would be appreciated.
Thx. GJ
RE: AutoCAD failed to install
make sure you remove autocad completly from the computer. when you go to reinstall make sure you have administrative privilages. that should work.
-sean
Does your system have the minumum requirements for installation?  Did you input the correct keycode for your software?  If everything is correct then follow deep6 post.  Hope this helps - John
Thanks ya'll, but this issue ended up being the DLO agent I have installed.  I had to close it completly and AutoCAD installed just find.  DLO is part of Veritas.
Sincerely,
G. Jackson
