Heat setting of compression springs?
I am looking for information showing the advantages and disadvantages of heat setting compression springs for automotive application. Free length of 1.25" and Diameter of about 0.20" Chrome Silicon.
Jackpot
Jackpot
RE: Heat setting of compression springs?
The disadvantage, is that it is more costly than setting at ambient temperature. However, it can result in a spring that is less costly if Cr-Si alloy steel can be made to work when otherwise a more expensive grade would be required.
