Table Driven Dimension into Dwg?
A vendor provided some hole location in X,Y format.
these holes are on the end face of a round body. (i.e. the
end of a tube) When I try to use the Hole Table feature in
the drawing there is no X axis or Y axis to pick (body is round) Is there a way to export the dimensions from the table into a table on the drawing without having to dimension each hole individually on the drawing sheet?
Thanks in Advance
Mike
Thanks in Advance
Mike
RE: Table Driven Dimension into Dwg?
Jason Capriotti
ThyssenKrupp Elevator
I'll try that and see how it goes.
