Is it possible to use sketch linked values for features in parts?
Is it possible to use sketch linked values for features in parts? That is directly, without having to fiddle around with tables or equations?
RE: Is it possible to use sketch linked values for features in parts?
Are you talking about sketch lengths from another model, or within the same model?  More details please.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Have you tried RMB and clicked Link values? You give the value a Name and from there when you want to link to that Dim you go to "Link Values" and pick that name.
For a feature you will first have to create, then come back to the dimension by Double clicking on the feature and going to the dim that away.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Thank you Scott, that was exactly what I was thinking of - I guessed it should be possible as it made no sense restricting link values to sketches and not features.
(It would have been great if there was a direct box for input during the creation of the feature though).
Saaaweeet!
I have wished that I could do that for a while. Just wasn't cleaver enough to figure it out. Thanks Scott.
