Auxilary view problem
Is it possible to create auxilary view that shows only certain face, or surface? I mean usually SW creates it by unfolding all visible faces etc. For example, if I have a pyramid, and I need to view auxilary (real image) just one face of it - how would you do it, specialists?
RE: Auxilary view problem
In your drawing, select the edge of the model that represents the face you want to see (usually from one of the standard projected views), then insert an Auxliary View. This will create a new view showing the face of the feature you selected.
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
