Best way to move files
What is the best way to move files if the files are assembly, sub-assembly, parts and drawings linked with them and they are all in different folders. Best way to move them yet have them all open properly. IF WE ARE NOT USING PDM.
RE: Best way to move files
Ray Reynolds
"Computers in the future may weigh no more than 1.5 tons."
Popular Mechanics, forecasting the relentless march of science, 1949
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
SolidWorks Explorer is good at copying a top-level file (drawing or assembly) and all of it's children, but you get to send the parent to one location and all children to one location. If the children need to be scattered to various directories, it can be a real pain. It also does not get drawings of the children. They must be copied seperatly. If they are going to the same directory as file they are referencing you will not have any problem.
If the directory structure will be the same at the destination as it is currently, just a different root structure, you should be able to move the entire structure in windows explorer. SolidWorks looks at a relative path before it looks at the absolute path. (go to the help file and search on "referenced documents")
