Flexible Subassembly
I am having trouble in retaining DOF in flexible subassemblies. For example, I am creating a complicated machine, so I have separated logical "chunks" of it into separate subassemblies. Lets say one subassembly has a moving part with only the req'd DOF: ie: a rotating shaft. I want to insert this subassembly, containing the rotatable shaft, into another larger assembly. When I do this, I can no longer rotate the shaft! And when I select >Properties>Solve as Flexible, ALL my constraints in the subassembly disappear.
Any suggestions? Thank you.
RE: Flexible Subassembly
