Plotting a 3D Parts for shaded or gouraud mode.
The problem is whenever I want to plot a hidden 3D model, shaded model or gouraud model, I can only have the 3D wireframe in the preview window and printout. which setting should I set in order to get the desired result. Could anyone help me to solve this problem. Thanks so much.
RE: Plotting a 3D Parts for shaded or gouraud mode.
Printing shaded or gouraud 3d objects can only be done in paperspace. When you try to print in modelspace it object turns into 3d wireframe. Currently, there is not a setting to change this configuration that I am aware of which will allow to print in colored 3d objects in modelspace. Hope this helps - John
http://support.autodesk.com/getDoc.asp?id=TS64610
