B31.1Stress due to sustained loads
Dear all,
As you know, ASME B31.1 states that stresses due to sustained loads are lower than Sh. When calculating longitudinal stress due to sustained loads only moments and pressure effect is taken into account but not stress due to axial loads (for example Bourdon effect). Does anybody know the reason? Or perhaps anybody knows, at least, where I can fing the explanation? (perhaps an ASME paper).
I don't really understand it....
thanks for any help
thanks for any help
RE: B31.1Stress due to sustained loads
Just my opinion.
BVI is correct, Pure axial stresses "seldom" are significant in real world systems. We did at one time (maybe 25 years ago) have a term in the equation for sustained longitudinal stress (aka -"additive stresses"). That term was simply the axial tensile or compressive force divided by the cross sectional area of the pipe (F/A). It was removed because the committee thought it was a needless complication.
Some of the current stress analysis computer programs either give you the option of including this term or (TRIFLEX) they put the term in regardless.
Thanks for bringing up the topic, it is nice to know folks out there think about this stuff.
Regards, John.
Depending on your exact setup, longitudinal stresses are often constricted, i.e. the component is not free to lengthen due to endcap reaction to bore pressure. This IS NOT the case when external loading induces components of stress in the longitudinal direction, you need to be very aware of this important fact.
Therefore the piping is modelled as a biaxial state of stress and not triaxial. On occasion this is not the case, the ASME B31.1 specification seems to be slightly misleading or at least, confusing, as you have correctly pointed out.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
