High Temperature Shut off valves 1502 F (820 C)
Max pressure 16 bar (232 PSI)
Bore ranges from 25mm to 50mm
End connections should be Flanged/weld.
Media: Contact gas: hydrogen, carbon dioxide, water vapour.
I need help to find a supplier who can supply this.
RE: High Temperature Shut off valves 1502 F (820 C)
http://www.emersonprocess.com/fisher/support/contactus/index.html
For the 25 mm valve a socke weld style would be more common.
I think this high a design temperature valv has been used in the gasification industry. Corrosion properties woudl also be of high importance.
