Non-orthoginal grid generation
Ok...I have to generate a non-orthogonal grid in a square domain..similar to what I have shown below....I would like to have the option of possibly changing the angle of rotation for the divide line.......Any suggestions...SO far I tried building up the grid using "for loop" statements but it takes a long time for fine meshes....I want to be able to use the meshgrid functions in Matlab..Any suggestions will be greatly appreciated..
Tony
RE: Non-orthoginal grid generation
It is not clear from your diagram what you mean. Use the TGML "code" tags to display it in a proportional font
eg
["code]
this is my code
["/"code]
(remove the " to get it to work properly)
M
Dr Michael F Platten
Mickey I tried to format it and I think it should make a bit more sense what type of mesh I am trying to achieve.
The entire domain is meshed but along the sloped line the entire mesh is flipped...The slope is say 45 degrees.
It's as if I have two meshed trapezoids along side each other
Tony
CODE
Ok guys here it is...I have loaded a proper GIF of the mesh I want to generate...Once you click the Link I believe you would understand what I am tryin to achieve using matlab
Mesh
