Irrigation using Greywater
I am designing an irrigation system using a buildings' greywater. The architect wants to use a gravity feed system. I have only 8-10 PSI. Normal irrigation remote control valve will not work. I would like help on equipment and filtration to use.
Thank you,
Brookwater
