micro pcb layout
micro pcb layout
i have a motorola star 12 mcu (144 pins). What would be best place to put that on a pcb layout. some collegues want to be on the corner of the board farthest away from the voltage supply and regulators.
i want to have in the middle so it makes routing easier for the other devices and for spi clock distribution.
what are your guys feelings/experiences with this.
RE: micro pcb layout
It is usually the analogue circuitry that gets upset by excess "bus noise" from the I/O. If there is no analogue circuitry then the only problem is getting the tracking onto the pcb.
What you haven’t said is why your colleagues want the chip up one corner of the board. This might help us give a more specific answer to the question.
