Dry Lube on sheet metal
We are attempting to use a dry lube on a coil line.  During humid weather the pinch rolls slip so that we don't get accurate feed lengths.  Any suggestions or experience with this process and lube method?
RE: Dry Lube on sheet metal
We put dry lube on wire.  It's the very, very last step because of these types of problems.  Will probably have to move lube or pinch rolls.
