problem loading drawings...AECBase...????
The whole office just switched over to ACAD 2002 and now I'm havng problems loading up drawings that have x-refs... it is not consistant (about 50/50 chance) but when it does happen it can take upwards of 2-5 min to load a drawing. The scripts I get are as follows
AECBase...
AECArchBase...
AECScheduleDataArch...
AECStructureBase...
AECArchDataBase...
AECSchedule...
This only happens on drawings with floor plan xrefs. my own drawings (with only a title block xref) have no problems...can anyone atleast explain why it slows my system to a crawl...
AECBase...
AECArchBase...
AECStructureBase...
AECArchDataBase...
AECSchedule...
RE: problem loading drawings...AECBase...????
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2753223&linkID=2475161
"Everybody is ignorant, only on different subjects." — Will Rogers
Borgunit is right. The *.dwg is made by ADT. The OE is not working? Why? Can the editor convert the ADT.dwg to ACADnude.dwg?
Lothar
ADT 2004
ACAD 2002
