Flow meter -orific plate
How do i calculate right size of orific plate for flow meter?
RE: Flow meter -orific plate
Get a copy of the Crane Technical Paper No. 410
"Flow of Fluids Through Valves, Fittings, and Pipes"
http://www.cranevalve.com/tech.htm
Here is a list of site that might help.
http://www.engrsoft.com/engrs3.htm
Fluid Flow Orifice Plate Sizing - Software
Yes, Engrsoft offers a program for sizing a multitude of orifice types. What makes ours better? Quite simply, ease of use. All of the data, including pipe data and material of construction are included. The program serves as an interactive design tool that...
http://www.flowel.com
Flowel: A total solution for orifice plate calculations. Flowel makes sizing orifice plates, nozzles, and venturis easier than ever. (English)
http://www.advanceinstruments.com/Sizing.htm
Orifice Plate Sizing Information Form
For fast and accurate calculation of Orifice Plate bores, Advance Instruments uses a program based upon the R.W. Miller Engineering Handbook. Please use the following form  more hits from:
http://www.yonkers.org/cae/inst.htm
Instrumentation Software - Orifice and Control Valve Sizing
Sizes Orifice Plates, Flow Nozzles, and Venturi Tubes. Produces an ISA type formatted output page (Spec Sheet) suitable for purchasing or engineering records
http://www.psi-kc.com/html/support.html
PSI- Sizing Guides
Sizing Guides and Support Files are available as a service from PSI. Please contact us if you have any questions with regards to the operation of the following files
http://www.chemisoft.com/
ChemiSoft
Check out EngrSoft, software that deals with many engineering topics including orifice plate sizing, distillation and liquid line sizing.
http://becon.org/~echoscan/14-19.htm
instrucalc
INSTRUCALC (IBM & compatibles) CAT.# 136-D01-36 INSTRUCALC features: * Control Valve Sizing-liquid flow; gas/vapor flow; two-phase flow * Flow Element Sizing-orifice plate, flange taps (liquid, gas/vapor); orifice plate, pipe taps (liquid, gas/v
http://www.caeconsultants.com/inst.htm
ORSPEC tm Sizes Orifice Plates, Flow Nozzles, and Venturi Tubes. Produces an ISA type formatted output page (Spec Sheet) suitable for purchasing or engineering records. $439.00 click on features for more info INSTRUMENTATION SOFTWARE (609)693-
http://www.rosemount.com/products/software/fsdownload1.html
Rosemount Inc. -- Download the Flow Sizing Program
This free software package contains the Instrument Toolkit capabilities, in a limited format. This software is designed to allow the user to easily size Rosemount Vortex and Magnetic Flowmeters. Experience the ease of the AIChE fluids database, including...  more hits from:
http://home.att.net/~james.b.allen
Process Control and Data Acquisition
Process flow calculators: everything one needs to calculate orifice bore, full scale flow, or delta pressure.
for liquid flow here is an Excel file in comma delimated format. Copy and save this as orifice.csv then open with Excel
Remove the " from around the formula and it should work. (the numbers in the column next to the formula are the results with the given example.)
--- PROGRAM BEGINS FOLLOWING THIS
ORIFICE PLATE SIZING FOR LIQUID FLOW,,,,,,,,,
"Tung and Mikasinovic, Chemical Engineering, Dec 12, 1983 p 69",,,,,,,,,
K vs beta correlation by JNS,,,,,,,,,
,,Find orifice size,,,,,Find pressure drop,,
Input Data,,,,,,,,,
,Flow rate,USgpm,,15,,Flow rate,USgpm,,15
,Fluid SG,,,1,,Fluid SG,,,1
,Pipe ID,in,,1.5,,Pipe ID,in,,1.5
,Press. drop,psi,,32,,Orifice dia,in,,0.375
Result,,,,,,,,,
,Orifice dia,in,"""=E10*E19""",0.374,,Press. drop,psi,"""=J19/144""",32
Calcs,Vel,fps,"""=(E8/7.5/60)/(PI()*((E10/12)^2)/4)""",2.716,,Vel,fps,"""=(J8/7.5/60)/(PI()*((J10/12)^2)/4)""",2.716
,Density,pcf,"""=E9*62.4""",62.40,,Density,pcf,"""=J9*62.4""",62.40
,Press drop,psf,"""=E11*144""",4608,,beta,,"""=J11/J10""",0.250
,K,,"""=2*E17*32.2/E15^2/E16""",645,,k,,"""=1.64863*(1/J17^4.29881)""",639
,beta,,"""=(1.64863/E18)^(1/4.29881)""",0.249,,Press drop,psf,"""=J18*J16*J15^2/2/32.2""",4566
--- END OF PROGRAM
lET ME KNOW IF YOU NEED A SPREADSHEET FOR GAS SIZING
Suggestion: Please, would you post more info about a kind of the flowmeter you have in mind.
A good question it all depends on the product you are trying to measure (single/dual phase, gas, liquid, slurry etc), also the overall accuracy (uncertainty) you are trying to achieve. International Standards covering the measurement of flow to high accuracy are again quite numerous, ISO 5167 (BS1042) and AGA 3 are probably the most widely used and are available from their respective organisations. If you require any further information please let me know and I can point you in a direction or two.
