underground pipelines inspection
What is the best technique/method should be used to
check/inspect the condition of the underground pipelines
without digging???
without digging???
RE: underground pipelines inspection
Hope this helps.
saxon
Can you get a borescope or video robot 70 miles down the pipeline?
JTMcC.
Look for a document “PIPELINE PIGS & PIGGING” on the internet by Pipeline Engineering & Supply Co. It is part of their Design and Application Manual. I have a pdf of the document I downloaded a few years ago; however, I took a quick look at their web site and did not see the document. You might drop them a note requesting this pdf. This gives a very basic discussion of pigging.
The question, Can we know the condition of the underground
pipelines without digging!!!
Are there technique using for that (like by thermal)?
Did you find the 33 page document, "PIPELINE PIGS & PIGGING" and determine that your pipeline cannot be pigged? Is this an insulated line that you are trying to check the insulation effectiveness? Please accurately define what specifically you mean by condition. I am not sure how you could check the condition of an above grade pipe line using a thermal technique let alone a buried one.
CRG
Check for leaks (Walk the line or shut-in pressure drop) is the most obvious and cheapest check, but tells you nothing about the intermediate condition and status of the line. Either it leaks or it don't.
Try a close interval survey (CIS) checking the potentials from pipe to soil and from pipe to same pipe at intervals. A gradient may indicate disbonding of the pipe coating and exposing the pipe to corrosion. This would be for external corrosion of the line. Corrpro can help with the DCVG survey. Look them up on the internet.
The above are the non-invasive checks. To go inside the line, borescope is you have access, but you are limited to what kind of access you have and only a local section of the pipe around the access.The line will have to be empty if it normally transports a dark fluid.
Smart pigging requires traps at the ends of the line. you will have to dig to put temporary traps in and then push the pig with compressed fluid from one end to the other. Geometry tools will gage the ovality of the line and let you know if there has been and gouging or deformation (from backhoe work) of the round pipe. Magnetic flux leakage will pick up internal (and external) wall loss of the pipe with some reasonable degree of accuracy. Cost is expensive and you will have to shut the system in for the test, but you will have definitive data on the condition of the pipe and which sections of pipe can be dug up and replaced.
Not knowing the length of the line and the size, I can't really give you a preferred recommendation to pursue. Hope these options help you get started on finding a solution to your problem.
Bob Lyons
PCS - Houston
