TIMBER POST BASE MOMENT CONNECTION
WHERE CAN I FIND EXAMPLES REGARDING DESIGN PROCEDURES FOR
DETERMINING FIXED BASE CONNECTIONS FOR TIMBER POSTS TO CONCRETE FOOTINGS.
ANCHOR BOLT SIZE AND SPACING, BASE PLATE
THICKNESS, BASE DETAIL CONFIGURATION, ETC...
THANK YOU...
THANK YOU...
RE: TIMBER POST BASE MOMENT CONNECTION
Sometimes it takes a little imagination and ingenuity but it can be done.
--BUT, FOR THE PARTICULAR SITUATION THAT I HAVE THE CLIENT IS LOOKING
TO SEE A STEEL BASE "SHOE" WITH ANCHOR BOLTS, ETC...WHERE ARE THERE EXAMPLES OF THIS METHOD OR SIMILAR METHODS...
(WHAT I HAVE IS AN APPROX. 4 FT X 8 FT SIGN ABOUT 17 FT HIGH)
THANKS...
Good Luck
[reading}
DO YOU KNOW OF ANY LITERATURE THAT ILLUSTRATES THIS APPROACH?
THANKS AGAIN
Anyone else out there have some ideas for lextoo?
check out deck designs there must be a moment connection there for you.
