ASTM A193 B7 Threaded Rod
I am looking for the UTS of the subject material.
I want to make a shear screw using 3/8-16 UNC and will turn the last 1/2" to size for shearing. I don't want to test this to determine the value.
Does anyone have this information? Thanks.
RE: ASTM A193 B7 Threaded Rod
B7 material - 2.5" and under in diameter
125 Ksi min UTS,
105 Ksi min yield strength,
321 HB or 35 HRC max hardness
