Primer systems and olefins
Currently using a silane-based primer system (with alkoxy and amine reactivity).  In general it works great in bonding polyester materials to polyolefins (like EVA, EMA, EEA, etc.).  Though strangely a good bond is not obtained when using any EAA resins.  It is understandable why LDPE would not work very well, but EAA is supposed to be a very chemically functional resin class - yet it can be peeled away from the polyester after being extruded upon the primer.    Quite confounding.     Any ideas?  (just bad luck with the chemical/primer matchup, or something strange about EAA's perhaps?).   Thanks for any insights.  :)
RE: Primer systems and olefins
Yes, this is confounding.  It should work.  Maybe the EAA is neutralized, or maybe it has a contaminant coating.
Tom Quinn
Adherent Laboratories
www.adherentlabs.com
