Changing Default Bend Radius
Can Anyone tell me how I can change the default bend radius for a sheet metal part?
Vik
Vik
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Changing Default Bend Radius
To edit it after the part is created, RMB the Base flange feature & select Edit feature, then change the Sheet metal parameters section.
If you double-click the "Sheet-Metal1" feature, the default radius will appear in the model window for editing. It is also possible to link the dimension to part thickness so that the radius matches thickness as thickness changes.
http://www.EsoxRepublic.com
Vik
