Mirror Solids with sketches
In Catia 5
How does one mirror a solid , along with it's associated skethes and sketch planes etc.?
You can do it in Catia 4...........easy.
puzzled
In Catia 5
puzzled
RE: Mirror Solids with sketches
I've been trying to figure out an easy way to mirror similar, but not exactly opposite parts, and the best I've come up with is to model the second part from scratch.
I have had to mirror everything with Surface Design.
Create new Sketches from the wireframes produced.
Then Re-Create the solid tree.
My client isn't a happy bunny.
Catia 4 ---30 seconds work.
Catia 5 ---2 DAYS.!
It's easy to say "I can't do this in V5 like I can in V4". The real challenge, and the real way to get the job done, is to ask "What is the end job that I need done", and find out how to do it. You will usually find that you can do it a different way in V5 than you did in V4, and you can save much time doing it that way.
In your case, Do you really need the support geometry mirrored? Or do you just need the final solid? Can you find a way to make the appropriate changes on the "original" part so that the final, mirrored part looks correct? Can you simply start with the original part mirrored and make some pads, pockets, holes, etc. to come up with the final part? Is there some common, fundamental geometry that could be put into a 3rd CATPart document, and then use that to create your left and right hand parts?
Much of the key to the power of V5 is not in simply creating the geometry. Building solids is pretty much the same in all CAD modellers. Some have these tools, some have those tools, but it all boils down to the same. The real key to the power of V5 is in it's ability to modify and re-use the design intent of your original designs, so that follow-on designs can be created faster.
I'll get off of my soapbox now.
However, I have to work to the ability of the lowest common denominator in my client's office. The 15 years on V4 dinosaur who doesn't want the bother of new 'gadgets'.
I can produce wonderous time saving trees and links and power copies.
Would the dinosuaur understand it, ? No.
That would be my fault then.
I've never done tail lamps, but I think you have a good solution: model common geometry, and then mirror and add unique features. I'd put the common geometry in one CATpart, and then link it into the right and left parts with one being symmetry'd.
But, this assumes you can easily store the data in your database (do you use PLM?), and it doesn't cause problems with downstream applications, like analysis and tooling.
...Jack
PLM can help you manage these types of links, however they will work in the file system as well. You may have to create some parts that don't belong in the BOM, but that shouldn't stop you - there are plenty of parts we end up creating in V5 that don't beong in the BOM but are necessary to get CATIA to work most efficiently (just as there are plenty of parts in the BOM that we don't model in CATIA).
