INTELLIGENT WORK FORUMS FOR ENGINEERING PROFESSIONALS
Member Login
Are you a Engineering professional? Join Eng-Tips now!
Talk With Other Members
Be Notified Of Responses To Your Posts
Keyword Search
One-Click Access To Your Favorite Forums
Automated Signatures On Your Posts
Best Of All, It's Free!
Partner With Us!
(Download This Button Today!)
Member Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
The Cornay appears to be a viariant of a cardan joint. Cardan joints only become CV joints if you pair them.No clue as to their claims for up to 45 degree angularity.A ball type CV joint is good for about 50 degrees.
Im more interrested in the claims of zero vibration. They also claim high torque figures, over 2000ft/lbs, which seems a bit much for a system being driven by such a "thin" ring... I don't know, they don't seem to answer my questions via email, ill see about giving them a call.
Dynamically it just looks like a double cardan joint to me, based on the second video. It looks a bit less agricultural (they are used on the PTO shafts of balers and so on) than adouble cardan, but I think it'll be the same.
At least one driveline supplier is pushing double cardans as a substitute for conventional CVs in some applications - they are probably more efficient than the six balls in groove type, but no better than a tripod. On the other hand they have higher articulation angles and less backlash than a tripod.
What kind of vibration does a tripod have according to the cornay demonstration video's there seems to be almost zero vibration, I was wondering to what extent, if any this can improve traction if vibration is completely eliminated.
A double cardan should have low torsional pulses/vibration, but wouldn't it tweak the input/output supports with the secondary couple just the same? I believe the secondary couple is what drives my poor old Volvo's diff and center-support nuts.
Secondary couple is term used in SAE Driveshaft manual. I think I recall It is not a torsional thing, but a transmitted torque related couple acting in the plane of the diveshafts. I also think I recall it is trying to straighten out the angle between the shafts. If the drive shaft meets the diff at an angle, the axle supports must restrain the diff nose from bobbing up and down at 2X. The reaction is trying to Tweak the driveshaft in a U at 2X.
Start A New Thread
DESCRIPTION: Transmission, Driveline, Hybrid Drive engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
