Line width of dimensions
i'm working wih I-DEAS 8m4 on Unix workstations. After modelling my parts I`m doing the drafting now. I want to set up different line width (very thin with 0.05 mm and normal with 0.3 mm) I`m able to change the line width for ordinary lines but i struggle to change it for dimensions. They always stay at least thin. Its possible to change the width to other pre installed styles but this is definately insufficient.
Thank you
Ilja
RE: Line width of dimensions
Ok, after solving the problem I will answer my self!
First of all, I I mean the line weight not width or anything….
The problem was to change the line WEIGHT of the dimensions to any other than the default value. I phoned the support and they gave me the final point.
The dimensions may not be changed to any other value than the preinstalled thin, thick and medium. The only way to get proper drawings is to change the line weight for the preinstalled weights. You have to open the masterdrafting.cfg with a text editor. Search for
mm_weights
     mm_weight 1() ! thin
     mm_weight 2() ! medium
     mm_weight 3() ! thick
     end
now you may change the weight by defining a new ascii file with the following content:
lineweight:
1.000000000000000E+00
2.000000000000000E+00
end:
the first number is your weight in mm and the second the pixel weight for the display (1-15). Be sure to use no breaks and spaces not signed here!
Type the filename of this short file right between the parenthesis.
mm_weights
     mm_weight 1(newthin.fnt) ! thin
     mm_weight 2(newmedium.fnt) ! medium
     mm_weight 3(newthick.fnt) ! thick
     end
That’s it. And, to my surprise, you can find all this in the bookshelf by searching for masterdrafting.cfg…..
I thank myself for a week of doom solving the problem of lineweights in the 21 century….
I love computers.
vanKoch
