Conductive Transparent Film
Does anybody know where I can source some transparent conductive film. I am told there is gold and platinum film commercially available but I have had no luck finding it as yet. I need several sheets A4 size for an experiment.
email me at patch@bigpond.net.au
Graham
RE: Conductive Transparent Film
How transparent?  Gold with something like 80% transmission is something like 150 angstroms thick, which is why you won't find it in sheets.  Ditto for just about any semi-transparent metal.
There are some electrostatic protection bags that are aluminized and are somewhat transparent.
TTFN
I'll go the other direction... how conductive?
Look for touch-sensitive resistive overlays for LCD.  Pretty clear (what, like 95%?), but resistance is generally several hundred ohms from one corner to the other.
Indium Tin Oxide is the film of choice for LCD shielding.
If you are interested in voltade/current distribution
modeling, you can use blotter paper soaked in electrolite
with AC.
<nbucska@pcperipherals DOT com> subj: eng-tips
