carbide insert for centerless grinders blades
Hi all , would you plaese route me to a manufacturer of such material . please?
Pardal
RE: carbide insert for centerless grinders blades
Kennametal makes carbide inserts.
Did you try a google search?
Yes I did, but I'm not sure the proper name of it .
It is called so?
And furthermore , which are the spec for this kind of part.
Hardenes or other related ?
Pardal
If you call kennametal they can probably direct you to a small supplier or their in-house tech staff that can get you what you need. I'm not sure how the crbide insert is used in a centerless grinder but all of the major carbide manufacturers probably have staff that will assist you.
As far as specs for carbide, well thats a grey area. There are proprietary specs per each manufacturer. AFAIK the rockwell A scale is used on carbide.
nick
