Tripod joint efficiencies?
I'm looking for any kind of rough formula I can use to calculate losses through a tripod joint at a given angle....even rule of thumb would be helpful at this point...
Travis G
RE: Tripod joint efficiencies?
Such formulas do not exist.
I disagree.
OP - work out the kinematics of your mechanism, use the known frictional characteristics of a ball or roller  bearing, and you should be able to work out the losses.
For small angles (say up to 5 degrees) the losses will be around 1%.
Alternatively talk to OEMs, I have definitely seen dyno data on this.
Cheers
Greg Locock
Zero at zero degrees and it goes up from there. You will also need a given torque and speed.
The 3 big balls have almost no friction, but they ride on needle bearings. That means you should be able to get what you need by a study of the needle bearings and energy spent on on reciprocating movement.
