Saving file properties in APL using (swconst.h) VRML
So I'm wandering through swconst.h (Properties for changing file saving) to be able to change the properties of saving VRML files. I cannot find the command for VRML version file outputs.
I want to save a VRML 1.0 file by using a macro(coded in VB),
However I want to make sure that the file is not a VRML 2.0 file
Is there someone who knows the command that can access the version of the saved VRML file.
Then once I access the command I am looking for how to implement it. I am using swModel.SaveAs4(sPathName,swSaveAsCurrentVersion,swSaveAsOptions_Silent,nErrors,nWarnings), but this will just save the file, not access the properties of the saved file
I know the command is in there, but I have been terribly unsuccessful in finding it.
Thanks in advance
Thanks in advance
RE: Saving file properties in APL using (swconst.h) VRML
However, the setting is located in the registry;
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2003\Export Settings\VRML Version
maybe this can help.
