Stop on Impact
Stop on Impact
I am looking to have multiple "Stops on Impact". I am designing a large assembly and would like these "Stop on Impacts" to remain associated with the parts even when I exit the "Move Part" command.
Basically I want to be able to move the different parts in my assembly without having them disapearing into other parts, but dont want to have to redifine it everytime I want to move something.
RE: Stop on Impact
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
RE: Stop on Impact
Once you get your part into place, define them to each other. After that you should be able to move one part and then they all move together.
Bradley
