Multiple Y-Axes
Multiple Y-Axes
Multiple Y-Axes
Is there a way to have two y-axes?  I am trying to lable Moment up the left axes and force up the right so I can place all the data on one plot.  Thanks in advance for any help.
RE: Multiple Y-Axes
Double click the data curve you want to move.
The window that opens gives you the option to select the primary or secondary axis.
Then double click each axis in turn and adjust the scale to suit.
But that's about as far as Excel goes, to my knowledge. I would love to be able to plot different parameters against multiple independent axis so if there is an answer to that, I'll be interested.
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
RE: Multiple Y-Axes
Thanks for your help.
RE: Multiple Y-Axes
It might depend on which version of Excel you have.  For Excel 2002 you can:
Click & select the series you want to have the second axis for.  Go to menu item "Format selected data series".  Click the axes tab in the dialogue, then check "Secondary axis" option.
RE: Multiple Y-Axes
Joerd,
a very useful link!
JMW
