How can i get the metal-foil that made by superclean stainless steel?
I need the superclean metal-foil for the research.
the ideal meterial is 316L stainless steel, double vacuum treatment, like vim/var.
i know the material hase widly used in the semiconductor equipment industry, but i can't get the foil type sample that made by 316L VIM/VAR.
the thickness i need is about 50~100 micro meter.
the size is not matter right now
Where i can get the metal-foil samples in the world? i do not want the metal-foil made by tranditional 316L material.
RE: How can i get the metal-foil that made by superclean stainless steel?
I would also do a search on Thomas Registry or GlobalSpec
http://www.espimetals.com/metals/catstainlesssteel.htm
http://www.hpmetals.com/index.htm
http://www.allfoils.com/products_stainless.html
We used standard 316 for process plumbing in a semi fab at a previous job. The facilities guys used LOX to clean the piping before installation.
TTFN
The major culprit, oxygen, generally runs as much as 100 ppm in 316L if it is Si/Mn deoxidized, whether it's VIM/VAR or AOD. If it's aluminum deoxodized, then again the AOD works equally well.
So a well-made AOD 316L can be cleaner, i.e. lower in oxides, than a VIM/VAR version. That being said Avesta specializes in such versions of 316L.
The material via AOD or VOD is usually acceptable for relatively non-conrrosive service. System desingers will often speicfy a "double melt" or "double vacuum melt" for corrosive service applications.
I need the superclean 316L to avoid inclusion in the 316L, espacially in metal-foil type. Because the metal-foil will be used in the precisely area applications and need suffer from critical manufacturing process.
so how can i get the samples for the research and study?
I meansion again about the sepec. of the 316L metal-Foil samples.
the thickness i need is about 50~100 um.
the size is about 170mm width.
