absorption chiller
absorption chiller
Is it possible to freeze the evaporator in a single stage absorption chiller with the unit off but with condenser pump on and tower water flowing through the condenser and chilled water pump off and no water flow through the evaporator?
RE: absorption chiller
Tubes approx 60 cracked in the evap. I know this can happen if the chilled water pump goes out but this happened with only water flowing through condenser.
