Common DC Bus ABB ACS800 Sizing
Hey Guys,
Can anybody provide any resources to determine how to connect two ABB ACS800 DC buses together? I have a 18.5KW motor under continuous regen (braking) which I want to connect to a 37.5KW motor. The system voltage is 690VAC. What I need to determine is the cable size and fusing between the two VFDs.
RE: Common DC Bus ABB ACS800 Sizing
Their website is www.abb.com or, for drive specific issues www.abb-drives.com
In the US, the Tech Service phone is 800.243.4384 but it doesn't sound like you are in North America.
I am an ABB Territory Manager and Certified Startup Tech so, if you don't have any luck locally, I might be able to help you thru email, etc.
Good luck.
