flatten a surface
flatten a surface
A product has a complex surface that I need to glue a label, I don´t know how to flatten this surface to get the real dimensions of this label, Does Catia V5 has this command ( to flatten a surface)?
Thanks in advance,
Angelo Matos,
Thanks in advance,
Angelo Matos,
RE: flatten a surface
Are you from Brazil? (B&D I think so)
In GSD Workbench has unfold command (insert/developement surfaces menu).
Thanks for your help. You are right, I´m from Brazil and I work at B&D since y2000 as a Project Engineer.
Angelo Matos,
amatos@blackedecker.com.br
