about ac regulation and protection
does anyone knows about ac regulation and protection for an application of about 30KW one phase?
id like to know methods or how to develop a protection.
regards
killa
RE: about ac regulation and protection
I am not sure I understand your question.
A Parameters Regulation could be defined as Change from no load to full load..
Regarding protection, which protection are you requiring? SC/OC? If you elaborate I might be able to assist.
ok, when in an audio application and powering subwoofers, you usually expect current peaks of about 10-12dB, that could lead to oscillations or insert heavy transients that could damage electronic equipment such processors and other sensitive equipment.
those equipment are 110VAC supplied, so im in the way of developing adequate protection devices to get rid of that.
usually smoke machines are phashe powered and insert noise, heavy enough to corrupt those equipment. discharge lamps start is another source of noise.
if anyone could help me to wisely  deal with that.
best regards
killa
