How do I Determine Input G-Loading Given Accelerometer Shock Response
I have shock response data (time) from a triaxial accelerometer. The task is to determine the shock load that the structure sees, using this response. I have the sampling rate and acelerometer specs. How do I begin to answer this question. I can reasonable assume that the system is a 1DOF system, obtain the transfer function and then do the inverse calculation to back out the input. Any thoughts?
RE: How do I Determine Input G-Loading Given Accelerometer Shock Response
Cheers
Greg Locock
The SRS has units of peak response accel (G) versus natural frequency (Hz). Damping is held as a constant, typically 5%, for this calculation. Furthermore, the calculation assumes a single-degree-of-freedom system.
So you will need an esimate of the natural frequency.
Tom Irvine
www.vibrationdata.com
