Loading Ramp Grades
Loading Ramp Grades
I have been asked to design a fork-lift ramp for building access. Apparently access to the building was overlooked when it was constructed last spring and this results in a very steep grade (3" per foot) on the ramp. My question is:
What is the maximum allowable grade for fork-lift loading ramps? Does anyone have literature that I may reference in my design package?
Any help would be greatly appreciated.
Caleb
Caleb
RE: Loading Ramp Grades
There is also an ANSI specification where it concerns fork trucks and the OSHA inspector was pretty tight on this requirement.
Also check your local codes as they have specific requirements. We had to prove that the ramps would never be used by a handicapped person.
Check standard but also sketch out the relationship between forklift wheel base, ground clearance, and the transition between ramp and higher floor. There is a chance of high-centering a truck even if the grade meets specs. Guess how I know.:)
Griffy
