Visual basic "if statements"
I wrote the following "if statements" in visual basic and referencing them to the same cell in Excel.  However, the statement meeting the right condition is being over ride by other statement not meeting the condition I specified.  Can someone help?  Thanks in advance.
If ((vI157) <= 0.25) And vN149 = 10 Then
        c = -0.7
        Range("I159").Value = c
        b = -0.18
        Range("I161").Value = b
     End If
     If ((Range("I152").Value / Range("I155").Value) <= 0.25) And vN149 = 15 Then
        c = -0.5
     If ((vI157) <= 0.25) And vN149 = 15 Then
        b = "N/A"
         Range("I161").Value = "N/A"
     End If
RE: Visual basic "if statements"
Is this all of the pertinent code, because it is missing an End If statement?
Cajuncenturion,
I am only showing an example of the code.  Is it correct to reference many "if statements" to one cell?  or do have to have many subs so they don't overide each other?
Thanks for your respond.
It is only a matter of the logic behind the if statements.  As you code is shown, since it's only a sample, it hard to find any logic flaws, should they exist.
CajunCenturion,
Below is part of my code.  I am trying to get the result "b" to show up in cell I161.  But, other if statement with the incorrect condition is over riding the correct if statement.  Thanks for your respond.
'public variables
Dim vG52 As Double
 Dim vG55 As Double
 Dim vG57 As Double
 Dim vd73 As Double
 Dim vN149 As Double
 Dim vI157 As Double
 Dim vI159 As Double
 Dim vI161 As Double
 Dim vG49 As Double
 Dim vG59 As Double
 Dim rr As Double
  Dim c As Double
  Dim cp1 As Double
  Dim cp1a As Double
  Dim cp2 As Double
  Dim cp2a As Double
  Dim b As Double
  Dim d As Double
Sub calculate()
 vI157 = Range("I157").Value
 vN149 = Range("N149").Value
If ((vI157) <= 0.25) And (vN149 > 10) And (vN149 < 15) Then
            c = -(((10 - vN149) * (-0.7 + 0.5)) / (10 - 15)) - 0.7
            b = -(((10 - vN149) * (-0.18 - 0#)) / (10 - 15)) - 0.18
    Else
         Range("I159").Value = "N/A"
    End If
        c = -0.7
        b = -0.18
     End If
     If ((vI157)) <= 0.25) And vN149 = 15 Then
        c = -0.5
        End If
        b = 0
     End If
 If ((vI157) <= 0.25) And (vN149 > 15) And (vN149 < 20 Then
            c = -(((15 - vN149) * (-0.5 + 0.3)) / (15 - 20)) - 0.5
            b = -(((15 - vN149) * (0 - 0.2)) / (10 - 15)) - 0
    End If
    If ((vI157) <= 0.25) And vN149 = 20 Then
        c = -0.3
        b = 0.2
     End If
     If ((vI157) <= 0.25) And (vN149 > 20) And (vN149 < 25) Then
            c = -(((20 - vN149) * (-0.3 + 0.2)) / (20 - 25)) - 0.3
            b = -(((20 - vN149) * (0.2 - 0.3)) / (10 - 15)) + 0.2
    End If
    If ((vI157) <= 0.25) And vN149 = 25 Then
        c = -0.2
        b = 0.3
     End If
     If ((vI157) <= 0.25) And (vN149 > 25) And (vN149 < 30) Then
            c = -(((25 - vN149) * (-0.2 + 0)) / (25 - 30)) - 0.2
            b = -(((25 - vN149) * (0.3 - 0.3)) / (25 - 30)) + 0.3
    End If
    If ((vI157) <= 0.25) And vN149 = 30 Then
        c = -0.2
        b = 0.3
     End If
end sub
In the following section of code, both If statements have unbalanced parenthesis, and there is an extra End If, which could be quite critical considering the two statements immediately preceeding it.
CODE
   c = -0.5
End If
b = 0
End If
Given (if I understand correctly) that nothing will happen unless vI157 <= 0.25, and the rest is based on the value of vN149, I would only check the value of vI157 one time, and then use a Case statement to differentiate between the values of vN149, something like the following:
CODE
If ((vI157) <= 0.25) Then
   Select Case vN149
      Case 10
         c = -0.7
         b = -0.18
      Case 11 To 14
      Case 15
         c = -0.5
         b = 0  ' Guessing Here because of the extra End if
' and you get the idea for the rest
      Case Else
   End Select
End If
CajunCenturion,
Yes, you are correct.  I made a mistake copying things and deleting.
However, ignoring those mistakes, do you think returning the answer to the same cell is a problem, i.e. overiding the correct if statement?
See previous post.
CajunCenturion,
Your input is very helpful.  Thanks for your help.
Structural01
