single switch reversing dc motor
Hello guys,my elctronics background is only decent but not completely ignorant.I need some help with a circuit.With a single switch(spst)control I need a 12vdc low amp(automobile window lift) motor to turn on and run in one direction for 2 seconds then stop, upon closing the switch the motor needs to turn on in the opposite direction and run for 2 seconds then turn off.The motor in question has two leads, reversing leads reverses direction.ANY help would be great! Thanks so much.
RE: single switch reversing dc motor
(It could be done with a half-bridge if you had +/-12V, but that's not available in a car, I guess
With the motor placed across the bridge you can control on/off and direction.
Exactly what to do, when the state of the switch is changed, can then be done in digital (micro-controller ?).
You could do it with a DPDT reversing relay and a SPST on/off relay, saving two relays.
If we learn from our mistakes,
I'm getting a great education!
Thats the original way I built it and it works well, but I would have to install two time delys for the 2 second intervals, one for forward and one for reverse. Then I started thinking would it be better to go solid state or IC. I have no problem with the way it is, I was just wondering if there was a more effient way.
The Infineon TLE5205 is an example of such a H-bridge single-chip that controls up to 5 amps.
Felix
